Calculating In(a)
Discussion in 'Math' started by sairfan1, Mar 2, 2013.
  1. sairfan1
    May 24, 2012
    46
    hi,
    i'm not very good in math, while solving some equation for an electronic project, i had In(R) where R is resistance, i want to know what is called this"In" in maths, how do we calculate this on paper.
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    You need to provide more information. I have no idea what "In" is refering to. Are you sure it isn't "ln" (lower case L)? If so, then that is the natural logarithm function. But that doesn't get you out of the woods because R has units and the argument to the natural log function, like the arguments to all trascendental functions, must be dimensionless.
  3. sairfan1
    May 24, 2012
    46
    thanks for help, i attached image file showing formula, i guess you are right, its related to logarithm.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Most scientific calculators do have the ln function. Included the windows calculator then in scientific mode
  5. sairfan1
    May 24, 2012
    46
    what is this "In" function called(full form), so that i could search to learn more about it,
    thanks.
  6. t06afre
    May 11, 2009
    5,939
    1,222
  7. WBahn
    Mar 31, 2012
    18,079
    4,917
    Since you've established that it is "ln", you need to STOP using "In". It is NOT "In".
    As for what it is called, re-read my first response:
    The formula you posted is fundamentally flawed because, as I stated before, R has units and the argument to the natural log function, like the arguments to all trascendental functions, must be dimensionless.
    At the very least, whoever came up with that formula is being unforgivably sloppy.
    sairfan1 likes this.
  8. sairfan1
    May 24, 2012
    46
    thanks, in fact i got confused, because on scientific calculator there is key "log" for logarithm and there is also key "ln" or may be "In", that's why i thought may be its related to that.
  9. WBahn
    Mar 31, 2012
    18,079
    4,917
    It IS related to that.
    ln() is the logarithm to the base e, also known as the natural logarithm.
    log() is the logarithm to the base 10, also knows as the common logarithm.
    The definition of a logarithm (well, one definition, there are many) is as follows:
    If x = b^y, then y is the base-b logarithm of x. That's all there is to it.
    For the ln(), b = e = 2.7182818284590452353602874713527....
    For the log(), b = 10
    But while this is the most common convention on scientific calculators, many programming language libraries do not follow this convention. Some use log() for the natural log and log10() for the common log. Mathematicians, in particular, like to use log() for the natural log and log_10() (a subscript 10) for the common log (on the rare occasion that they use it).
    The bottom line is that you need to gain an understanding for the fundamental concepts at play so that you can place yourself in a position to figure out what is meant in a particular situation instead of relying on memorized "facts" that often aren't as engraved in stone as we would like to believe.
