calculating heatsink for LM350At..need help!
Discussion in 'The Projects Forum' started by ayane, Oct 12, 2009.
  1. ayane
    Thread Starter Active Member
    May 3, 2009
    39
    i am looking for a heatsink. I am new to this henc i am not sure on how to calculate.
    Input supply ( from solar cells) : 15.6v, 1.33A ( max)
    ouput of the regulator is 12.85V.
    Power dissipation: ( 15.6-12.85)* load current ( approx 1.3) = 3.575w
    Everytime i run the lm350 it gets very hot. I had tested on the dc supply , the regulator switch to its thermal protection by limiting the current.
    jc- junction to case, cs- case to heatsink, sa- heatsink to ambient
    the junction temperature must not exceed 125 degrees.
    can i neglect Rcs?
    T(junction)- T(ambient) = Power loss ( Rjc + Rcs + Rsa)
    125- ( how do i determine?) = 3.575( 3+ Rsa)
    Rsa is to determine he minimum thermal resistance of the heatsink?.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Too much math. Take a 5W or 10W power resistor, the ceramic kind that has an aluminum flange for mounting on a flat surface. Or better yet, one like this. Temporarily screw it to a 4" square of aluminum, about 1/8" thick or thicker. Hook the resistor to a power supply, adjust the voltage until the resistor is dissipating ~4W. E=sqrt(4/R).
    In the final application, can you mount the heatsink vertically or horizontally? Set the aluminum plate in the same orientation. Let it reach thermal equilibrium (might take a few minutes). Measure the temperature of resistor body and the plate near where the resistor is mounted.
    If the body of the resistor body is hotter than ~75 degC, you need a bigger heatsink, or it needs to be placed vertically instead of horizontally. If the temperature is < 50 degC, then you can make the plate smaller.
    If you have a heatsink in the junk box, you can use this test on that, too.
  3. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  4. ayane
    May 3, 2009
    39
    thanks for the link..will try to understand the concept.
  5. ayane
    May 3, 2009
    39
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  7. ayane
    May 3, 2009
    39
    noted..had purchased some mica.. any negatives to screw the ic with a nut to the heatsink?.with the mica in between to provide insulation?..
    will be switching the heatsink once i completed my testing on my breadboard..thx..
  8. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    It can be that the adjust pin is connected to the housing.
    The regulator will give the wrong outpout when this is grounded.
    There are isolation rings to mount it isolated from the heatsink.
    Greetings,
    Bertus
  9. ayane
    May 3, 2009
    39
    noted thanks
