Calculating emf help
Discussion in 'The Projects Forum' started by Ziggey, Nov 28, 2015.
  1. Ziggey
    Nov 4, 2015
    15
    Does all this look right? To you guys?
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    Cant see the question, so i don't know what you're doing...
  3. wayneh
    Sep 9, 2010
    12,382
    3,239
    You started with dimensions but lost them by the end. Don't get sloppy and lose track of your units. It'll be far easier to check your work, especially for others.
  4. ScottWang
    Aug 23, 2012
    4,929
    777
    The files size that you attached were too too big, I was compressed it to the normal size from about 3.9MB to 83KB, next time before you upload the files, please compress the photos to 800x600 or 640x480, if necessary then you can compress to 1024x768, almost the photos using 800x600 image is enough, even using the smart phone also has the app to compress the file.
    Too much file size will affecting the connecting speed of members to get into the forums, thanks for your understanding and cooperation.
