Calculating Base Resistor on BJT
GioD
Joined Mar 20, 2009
30
Moderator Note: This thread has been split from Calculating Base Resistor for a BJT
I don't see in the diagram the resistor usually connected from Base to Emitter. What's the utility of this further resistor ? Is always necessary or not ?
wayneh
Joined Sep 9, 2010
17,498
You've reopened a 5-1/2 year old thread. If you have a question on something, you should start your own thread.
And no, this circuit doesn't need a resistor from emitter to base. If you supply an example of such an arrangement, someone here will explain it to you.
34,470
Regarding Beta, in most cases i have seen people using 20 for calculations., however it depends on which transistor (Parameter) you are using.
If you look at their data sheet, most BJTs are specified at a Beta of 10 for the Vce saturation voltage measurement, so that is why a value of 10 is commonly used when you want the transistor to be fully ON.
Of course you can also use a logic-level MOSFET, which requires no gate current, to control the LEDs.
