Calculating and displaying power consumption of a load through battery
Discussion in 'The Projects Forum' started by ammarqs, Mar 12, 2010.
  1. ammarqs
    Mar 12, 2010
    I am a student of electronic engineering. I have a project in mind and tht is calculating the power consumption of a load through a battery. For this i have some idea in mind and tht is connecting an ADC for the battery and convert it to digital, and thn connecting it to a micro controller. Here the problem arises is how do i actually calculate and display the power given out my a battery.?? and one with any idea and considering to help are most most welcome.
    Thank u in advance
    Ammar Surti.
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    The project has merit. If I understood your description you indicated that the micro would be running on the battery under test. I would advise that the microcontroller measuring the batteries health be powered by its own dedicated power source.
    hgmjr
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    P=E*I
    To get power (P), you will need to measure the battery voltage (E) and the current (I) to the load, then have the micro do the math.
    Ken
