calculate voltage out class d inverter
Discussion in 'The Projects Forum' started by id_ruben, Oct 29, 2012.
  1. id_ruben
    Oct 27, 2009
    7
    How to calculate voltage output class d inverter.
    Is this scheme can produce 220V AC, and how to modify them to be reliable and safe inverter.
    How to calculate voltahe at point 2a&2b
    How to modification this "inductance heater" becomes Inverter
    Thank you
  2. crutschow
    Mar 14, 2008
    13,462
    3,353
    Why do you think the first circuit can produce 220V? It can't. It can't produce a waveform greater than the supply voltage, in this case peak voltages of 0V to 12V. To increase the voltage you need a boost-converter configuration or a transformer.
    In the second picture, the voltage depends upon the value of the inductances and capacitances.
  3. id_ruben
    Oct 27, 2009
    7
    what should i do to modify second picture to inverter
    than you
