Calculate voltage across capacitors in series
Discussion in 'Homework Help' started by matthewd, Jun 19, 2015.
  1. matthewd
    Jun 19, 2015
    Hello to All
    My homework question is –
    “A 3uF and a 6uF capacitor are connected in series to a 24 V a.c. 50Hz supply. Calculate the voltage across each capacitor”
    I researched how to answer this one and found this –
    https://answers.yahoo.com/question/index?qid=20100219094359AADPjZR
    The best answer states that -
    Xc = 1/(2pi fc) = 1/[(6.28) x (20) x (.0001) = 79.6 ohm
    Impedance angle = arc tan Xc/R = arc tan (79.6 ohm) / (56 ohm) = 54.87 degrees
    Voltage across the capacitor = (sine of impedance angle) x (Input Voltage)
    Vc = (sin 54.87 degrees) x 10 VRMS = 8.18 VRMS
    I have done the first line of this equation and I have –
    1/2xPiex50x0.000003= 1,061.03 Ohm
    Now when I come to the second line of the solution I am totally stuck, I don’t have two impedance values to get the impedance angle from, so I don't really know how to proceed.
    Or if anyone knows a simplier formula for calculating this one I would appreciate it - I have a feel I have missed something with my approach.
    Thanks,
    Matt.
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    Yes, you did miss something. You are looking for a solution before analyzing the problem and making it a much harder problem then it is. :rolleyes:
    Note that, to solve an engineering problem, you don't always need all the information you are given.
    Instead of looking for a canned solution, you need to think a little more about the problem.
    It has only capacitors in the circuit so you don't need to do impedance or phasor calculations or even know the frequency of the power supply to solve that problem. You just have to know the relative AC impedance of the two capacitors, which is independent of frequency, and use that to calculate the relative voltage drop of each capacitor.
    I trust you can do the rest.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are trying to imitate a monkey imitating an engineer. Don't do that.
    Look at the problem from basic principles and apply what you know, not what you can find that someone else claims to have done on a problem that is unrelated.
    You are looking for formulas to throw numbers at without making any effort to even understand what the formula means, let alone whether or not it applies to your problem.
    Note that one assumption that you do have to make is that the capacitors are initially uncharged (or that they at least have the same charge on them).
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    But any initial charge doesn't affect the AC voltage division.
  5. DickCappels
    Aug 21, 2008
    2,773
    669
    With an ideal capacitor if one of both had initial charges the initial charge would remain as a DC offset to the voltage across the capacitor(s). Of course we can figure that the questioner was only referring to the AC component of the charge. Wait…since it is AC, can't we just say that the net change across each capacitor is zero?
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    If you have a voltage of 100 V DC and that voltage is going up and down sinusoidally by 1 V AC, what is the voltage on that capacitor?
  7. crutschow
    Mar 14, 2008
    13,501
    3,375
    I would assume the question is only referring to the AC voltage across the capacitors since no DC voltage is mentioned.
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    Which is why I specifically stated that "one assumption you have to make is...."
  9. shteii01
    Feb 19, 2010
    3,504
    512
    Step 1.
    Convert capacitances into impendances. I don't waste my time with stupid reactances.
    Zc=1/(j*2*pi*f*C)
    Step 2.
    Use voltage divider formula.
  10. matthewd
    Jun 19, 2015
