do we need to assume the current that pass by the motor?
if not, how cound we know how many current pass throught the motor and the total current in this circuit?
Have you considered using a small valued resistor less that 1 ohm in series with the positive power supply input across which you could measure the voltage with a digital voltmeter. Then use Ohms Law to calculate the current.
