Calculate the power dissipation
Discussion in 'General Electronics Chat' started by dileepchacko, Oct 14, 2009.
  1. dileepchacko
    Thread Starter Active Member
    May 13, 2008
    102
    Calculate the power dissipation of MOSFET (M1) as well as shunt resistance (R5). The condition is the drain of the MOSFET short to Power supply (14V).
    I have attached the circuit diagram as well as MOSFET data sheet.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You don't have a voltage for V2. Are we to assume that V2 is 0V?
  3. dileepchacko
    May 13, 2008
    102
    Assume the mosfet is completely switched on.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    If your mosfet is "completely switched on" the the power dissipation of MOSFET (M1) will be as for any resistor UxI or (IxRon)xI
