calculate the power absorbed
Discussion in 'Homework Help' started by kd3041, Feb 2, 2011.
  1. kd3041
    Feb 2, 2011
    7
    Hi guys. I have a problem of calculate p1 in this question. p4=4x20=80W
    p3=4x12=48W. p2=8x6=48W but how do you calculate p1? Theres only dependent current of 2 A known. Thanks
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    The diagram can tell you the value of I, as well as the voltage applied on the source P1. It just does that indirectly. Can you see it?
    Hint: these quantities are defined by other sources.
  3. kd3041
    Feb 2, 2011
    7
    is it 8V cos the current source is in parallel with the 8V
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Yes. How about the current I. Can you find it?
  5. kd3041
    Feb 2, 2011
    7
    yh 2 A. Thanks
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Exactly. I is the same as the current flowing through source 4, as they are in the same branch. Thus the current through source 1 is 0.5I=2A.
