calculate slew rate and gbw.
Discussion in 'General Electronics Chat' started by hiren.dave, Sep 12, 2012.
  1. hiren.dave
    Jun 22, 2012
    20
    i want to calculate slew rate and gainbandwidth product with following parameters.
    pulse amplitude: 23 to 30mV.
    pulse time: 140ns.
    gain: 47 times.
    help me to calculate slew rate and bandwidth for this parameter. it's better if you suggest a particular IC.
    thanks,
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    What is the shape of the pulse?
    What is the rise and fall time of the pulse?
    Bertus
  3. hiren.dave
    Jun 22, 2012
    20
    friend,
    I don't know the pulse rise or fall time. and pulse shape should be half of cycle of sine wave.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I assume this thread is a continuation of your last thread:
    detect pulse of 140ns and 50mv.
    Now you want to amplify the 23 mV pulse to about 1 V.
    The slew rate must be higher tan 1 V / 70 nSec = 14.3 V / μSec.
    The GBW must be higher than (1 / 280 μSec) * 47 = 168 Mhz.
    Bertus
    PS I have posted the same answer in your other thread.
    I can merge the threads if you want to.
  5. hiren.dave
    Jun 22, 2012
    20
    thanks again my friend...
    Yes, this thread is continuation with my old thread.
    I was little confused, so i post a question again.
  6. hiren.dave
    Jun 22, 2012
    20
    friend, you told me that i should use opamp with minimum 70V/us slew rate. and now 14.3V/us.
    which one should i use?
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    The 70 Volts / μSec is for a 5 Volt pulse.
    The 14 Volts / μSec is for a 1 Volt pulse.
    Bertus
  8. hiren.dave
    Jun 22, 2012
    20
    thanks again my friend.....
