calculate saturation current of ferrite pot core
Discussion in 'General Electronics Chat' started by darsie, Aug 26, 2014.
  1. darsie
    Feb 19, 2010
    15
    Hi!
    How do I calculate the saturation current of this P-core:
    http://ferrite.ru/uploads/pdf/products/pot/p_18_11.pdf
    Ordering code: B65651+0400A048
    Gap: 0.1 mm
    Material: N48
    l_e=25.9 mm
    mu_e=192
    Ferrite N48
    www.epcos.com/blob/528870/download/3/pdf-n48.pdf
    Flux density (near saturation) (f = 10 kHz) B_S (25 �C)= 420 mT
    http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/toroid.html says:
    B*2*pi*r=mu*N*I
    So I assume substituting 2*pi*r with the core length will work
    aproximately with a P-core, I do:
    NI=B_S*l_e/mu = 0.42 T * 0.0259 m / (192 * 4E-7 * pi) = 45 A
    I don't believe 45 A. I have a 26/16 P-core (without specs, 26 mm diameter, 16 mm high (per set with 2 halves)) with saturation current of 3.5 A. Even though the P1811 has 0.1 mm gap 45 A seem too large.
    I want to know this before I buy the core.
    Thanks, Bernhard
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    You calculation are correct. You simply have N*I = 45 Amper-turns = magnetomotive force
    Personally I use this equation
    Use this B = ( AL * N * I )/Ae
    For your core
    AL = 400nH/n²
    I is a current in Amps.
    Ae - effective cross sectional area = 43mm²
    So for example
    I = 3A and N = 10 we have
    B = (400 * 3 * 10)/43 = 279mT.
    so for NI
    B = ( AL * NI )/Ae
    B*Ae = AL * NI
    N*I = (Bmax * Ae)/AL = (420 * 43)/400 = 45A turns.
    so for 10 turns we have I_sat = 45At/10t = 4.5A and don't forget that this is a peak value.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,546
    512
    Dont forget that the saturation flux density can go down quite a bit with temperature, which means you should check out the temperature characteristics of the core material too.
    Core heating can occur because of ambient temperature rise or power heating.
