Can someone please help with this, I haven't got a clue where to start
Nope it's an assignment for my college work!hi 99,
You have not been given sufficient information about the components in that circuit to enable you to calculate the exact values.
The LDR as you may know is a Light Dependant Resistor, the LED operating current is not specified.
Is this Homework.?
E
I should be a to, I'm in college now I'll check with my tutor sometime soon and I'll let you know, thanks for the help!hi,
OK, Lets assume that the LED is a general purpose type, say 25mA maximum current.
Its usual to under run this maximum current in order to extend the life of the LED, so assume 20mA, also assume a 2V drop across the LED.
Also assume that the voltage drop across the transitor [ collector to emitter ] is 0V.
Can you calculate the value of Rload that allows a current of 20mA to flow.?
E
Do we know it's a 470? Or am just trying 470?Try a 470 ohms resistor for starters..
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Jerry Twomey
