Hi guys,
Pretty n00b to a lot of this stuff. I came across a laptop computer the other day with a choke on the inside (straight after DC). I began to look at the chokes on other laptops I had lying around. Some are beads, some are cylanders with the center drilled out and the wire passes through the center.
I would like to know how to calculate the Inductor values of some of these chokes with some sort of basic circuit.
I have a scope but not a signal generator - my searches on this forum makes me think I will need a signal generator.
I know its made of material 44.
I also think that I might be able to calculate the henries based on the physical properties of the choke? length, OD/ID diameter, material etc.
Cheers in advance,
-Al
Cheers in advance,
-Al
