Calculate Current
rohanbhatia
Joined Mar 15, 2012
Hi... I just started embedde3d C at uni and the prelim work had this question... i dont remeber much from my first year at uni so would appreciate the help.... These are the 2 questions....
  1. How much current will the LEDs draw?
  2. How do we make the Z8 supply this current from these pins?
jtrent
Joined Mar 11, 2012
26
OK, to calculate the current in your circuit, I am making a couple of assumptions.
  1. To light your LED, you are placing ground or zero volts on the cathode of the LED
  2. The voltage drop across the LED is approximately 2 volts
see my full comments here
