calculate current in transistor circuit
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Sep 7, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    is there is circuit has alot of transistors and show all the current because i need to understand how to calculate the current in big circuit has alot transistors
    thanks
  2. praondevou
    Jul 9, 2011
    2,936
    489
    I don't think it will be easy to find such a schematic, since signals in these circuits usually change dynamically and therefore current (that also changes) will not be indicated.
    If I wanted to do something like this I'd take any DC circuit that contains a number of transistor or I'd look for IMAGES on Google typing for example "schematic transistor". You pick one of the thousands of schematics, put it into a simulator like SPICE or MULTISIM or any other. Let it do the calculations for an DC-input signal . Then you do your own calcs and try to understand what the simulator calculated and if there are discrepancies.
    Don't choose oscillators or audio amplifiers to start , it will get too complex.
    TAKYMOUNIR likes this.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    The way to figure a current budget is to break the circuits down into one section at a time, figure the current, and add them all together. It can be a long list!
