Calculate by any method everything
Nara Shikamaru
Joined Nov 24, 2007
92
Hey everybody, i need to calculate by any method the uploaded circuit, it was made at ramdom selection of components, and i need to do all the calculations for optimal behavior and design, please help me!
Papabravo
Joined Feb 24, 2006
21,225
It is hard to know which calculations you have in mind. Could you tell us something about what the device is supposed to do?
Nara Shikamaru
Joined Nov 24, 2007
92
The Device its a Level meter and Activates an alarm and a motor , when it reches certain values, and the LCD shows constantly the level.....the things needed to be calculated are all the resistors, the Voltage source components and currents and voltages
KMoffett
Joined Dec 19, 2007
2,918
Since this is in the homework forum, I think Nara wants to show calculations that would be used to spec the value of each component in the schematic.
Like (Vcc-VD1)/10mA=R2 and (Vcc-VD2)/10mA=R3
Ken
Nara Shikamaru
Joined Nov 24, 2007
92
Exactly! at least i would need to know wich Calculations must be maid to calculate every component for Optimal Operation.....in the circuit all values are labeled....but they were label Empirically.....those values weren´t calculated....
KMoffett
Joined Dec 19, 2007
2,918
