Calculate an unknown resistance
Discussion in 'Homework Help' started by Kango, Oct 20, 2007.
Thread Status:
Not open for further replies.
  1. Kango
    Thread Starter Active Member
    Sep 22, 2007
    30
    I need help calculating R3 in the circuit. I have calculated R2 and R1 to the following:
    R1 = 2800Ohm
    R2 = 5000Ohm
    Specifications:
    Vref = 5,6V
    I14 = 2mA
    Vo = 0-10V
    The electric current throw the diode = 6mA
    The circuit.
      File size:
      22.4 KB
      42
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Hint: have you studied Kirchhoff's Current Law (KCL)?
  3. Kango
    Sep 22, 2007
    30
    Yes...
    However I was thinking this
    V = 15V
    I = 6mA from the zenerdiode
    R = V/I = 2500Ohm, can that be correct?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    No. One end of R3 is at 15 volts, but what is the voltage on the other end?
  5. Kango
    Sep 22, 2007
    30
    On the other end it is 5,6V.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    OK, so what is the voltage across the resistor?
  7. Kango
    Sep 22, 2007
    30
    Now im getting tired of you, look at the picture, if you don´t wont to help me, then stop ask all this question!
    I want a fast answer. I have no time playing this game of yours, the reason im asking here is because I dont now the answer. If you dont like to help me then you can stop thrasing this thread. I dont want this to take a week, this is just a small question that I had.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I thought this was homework. Giving you the answer is not going to help you. I was trying to lead you through the problem-solving process. Why don't you take a long walk off a short pier.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This thread has become unproductive and a waste. I am goin gto close it from further postings.
    A notice to the OP - it is your responsibility to do the work. We - as the AllAboutCircuits community - are willing to help, but only if you have done some work. This is not an answer on demand site. You may either take this to heart or choose not to make postings in the future.
Thread Status:
