I have an AC circuit which has suffered from a welded relay contact and want to use an MOV to protect it.
I have two 240VAC inputs (redundancy) feeding a 50VA toroidal transformer via a (two contact) relay. When AC1 is present the relay is energised and AC1 feeds the toroid. When AC1 fails the relay de-energises and AC2 then feeds the toroid. One relay contact switchs Live (hot) and the other Neutral. The secondary circuit is 24VAC. However during this transistion one of the relay contacts has welded and I suspect this is caused by arcing (high voltage). I'd like therefore to put an MOV in parallel with the toroid and have got this far:
Working voltage: 240V + 10%= 234V
Peak current: 2.08A (50VA/24VAC)
But I do not know how to work out the transient energy, power dissipation or clamping voltage.
Help!!
Help!!
