And those 2 LEDs are in series, right?Parallel
1 resistor per 2 led
No worries, but there are some nuances with LEDs. Actually putting them in parallel will cause them to share current differently, making some light and some dim. Then some melt and the others light, then they all become dim forever.Yes, (c)..sorry, I'm new to this
Like the above said, in parallel there might or might not be some variation in brightness between the parallel branches. To even out the brightness, you may have to "play around" with resistors. Put a slightly larger resistor at the brighter branch or put slightly smaller resistor on the dimmer branch, or do that to both branches.No worries, but there are some nuances with LEDs. Actually putting them in parallel will cause them to share current differently, making some light and some dim. Then some melt and the others light, then they all become dim forever.
Thread starter | Similar threads | Forum | Replies | Date |
Mosfet Heat Calc | Analog & Mixed-Signal Design | 25 | ||
MOSFET Power Loss calculation ? | Power Electronics | 41 | ||
Understanding LED Arrays and R(D) Calc | General Electronics Chat | 12 | ||
Strange "Feature" of LibreOffice 5.1.6.2 Calc | Off-Topic | 6 | ||
-1.20E-003 equals -0.001196 in Open Office Calc? | General Electronics Chat | 2 |
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
