Cable shielding
Discussion in 'General Electronics Chat' started by Dritech, Mar 13, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
    I will be passing signal cables and DC motor power cables in the same cable carrier. To eliminate interference in the signal, I decided to use shielded cables.
    Is the one in the attached photo good for this application or shell I buy a cable with an overall shield?
    Thanks in advance.
      File size:
      268.4 KB
      32
      File size:
      281.6 KB
      30
  2. #12
    Nov 30, 2010
    16,671
    7,314
    That IS a shielded cable. Look deeper and see that the copper is wound spiral on the outside of the insulated conductors.
  3. Dritech
    Sep 21, 2011
    756
    5
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    With DC motor cables it is usually sufficient to twist them tightly unless already in a sheathed cable.
    This tends to cancel out any radiated EMI.
    It is the encoder cables etc that need shield, if used.
    Max.
    Dritech likes this.
  5. #12
    Nov 30, 2010
    16,671
    7,314
    Arrgh! It takes a lot of reading and research to find the very best. Spiral wound, braided, aluminum foil with a runner wire, aluminum foil AND a braid...the proof is in the specs. Running the motor power in one twisted, shielded pair cable and the signal in another would give (2) two layers of shielding.
    Dritech likes this.
