Cable fault locator for underground PSTN cables
Discussion in 'The Projects Forum' started by efarook, Jun 16, 2010.
  1. efarook
    Aug 5, 2009
    Hello everybody,
    I want to build a cable fault locator for my own use. I know there are some ready made stuffs out there in the market, but I want to build my own version.
    This fault locator will be able to monitor and detect open and short cable faults. This is simple, I will be able to design a circuit for this.
    But what I could not get after a long search on the net is that how to locate the fault. I read about TDR (Time Domain Reflectometry) but this is not so handy for my field use.
    Are there any other simpler techniques to find the location of the fault?
    Thanks in advance.
  2. Bernard
    Aug 7, 2008
    4,248
    423
    It would be helpfull to know more about the cables. Is access available to ends of the cables? How long are the cables. My experiance with cable fault detection was with 13 pair, 1320 ft, on surface cables that had plugs on each end. One step used a capacitance bridge for opens, good for about +- 10 ft. Resistance measurements worked fairly well for shorts. Tone tracing located fault to +- 1 inch.
  3. studiot
    Nov 9, 2007
    5,005
    515
    +1
    What are they under? "underground " is too vague.
    Since they are underground do they have an earthed armoured sheath?
    In which case TDR may be your only option for an intenal break, although you can send a signal down the sheath.
  4. JoeJester
    Apr 26, 2005
    3,403
    1,229
    You can make a TDR with an oscilloscope and a pulse generator.
    The rest is knowing the velocity factor of the cable and the time difference between the main pulse and the return pulse. It's based on the same philosphy as radar.
    It will not get you down to an inch ... you could get close if you know how and your oscilloscope is equiped with the venier dial and a delayed function.
    on edit
    http://www.epanorama.net/circuits/tdr.html
  5. loosewire
    Apr 25, 2008
    1,584
    435
    This Is just for fun- A very good cable locator-
    A backhoe,works every time.
  6. davebee
    Oct 22, 2008
    539
    46
    Where I live, the underground residential power cables regularly corrode and fail.
    What the repairmen do to find the location is isolate the failed cable section, send a high voltage down the isolated cable section, then walk along the ground above the cable path and listen for the sound of sparking!
  7. retched
    Dec 5, 2009
    5,201
    313
    Thats true. We have had a tech use audio to find power and water supply line faults.
    You can also use FLIR, depending on how BAD the fault is.
