Cable - Capacitance, Resistance,inductance
Discussion in 'General Electronics Chat' started by vineo763, Oct 2, 2006.
  1. vineo763
    Aug 13, 2006
    12
    Cables often have specifications such as resistance, inductance, and capacitance. Does anyone know how I should measure these specifications? Is it as simple as using a multimeter?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Cable parameters cannot in general be measured with a multimeter. Since they are distributed paramaters capacitance, inductance and resistance are usually measured per unit of length. DC resistance of a conductor can be measured with a multimeter but that measurement is of little practical value since we are generally more interested in the cable parameters as a function of frequency.
    The top of the line instrument to measure cable parameters is a network analyzer; it is a pricey bit of gear. There are also a variety of other instruments that take more work but yield similar results.
  3. bhavesh96el
    Member
    Apr 24, 2006
    11
    Papabravo.. I did understand what you said that cable parameter is function of frequency.
    But i didn't understand is how can we measure the capacitance and inductance of cable using network analyser ?
    From frequency response impedance Z can be derived
    but then how can we derive capacitance and inductance?
    I guess we can say the attenuation dB/m using Network Analyser.
    REgards
  4. bhavesh96el
    Member
    Apr 24, 2006
    11
    Papabravo,
    I understood that cable parameter is frequency dependant.
    Frequency respone,obtained from Network Anaylser, can be used to derive impdance (Z) of the cable.
    However, I can not figure out how can we obtain Capacitance and Inductance from it ?
    Regards
    Bhavesh
  5. CATV
    Member
    Apr 17, 2007
    11
    Using a network analyzer, you can get the output presented in a Smith Chart format which will show you the capacitaive and inductive compnents of the transmission line. Call Comm/Scope in Hicory NC and they will give you more details.
  6. Tube Tech
    Jan 11, 2007
    46
    With a tape measure. The paramaters you describe are listed in picofarads per 100 feet, et cetera. Measure and calculate.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    With good cable, we don't need a tape measure. Footage should be printed on the cable every one or two feet.
    Network analysers are expenisve to buy, but there are many places where such can be rented.
