CA3240 Op Amp Question
Discussion in 'General Electronics Chat' started by Tom1962, Sep 28, 2012.
  1. Tom1962
    Sep 10, 2012
    19
    I am going to use this op amp CA3240 as a voltage follow, see data sheet below. I was planning to use this in a 5 volt circuit -- i.e., so the chip is powered with 5 volts. When use it as a voltage follower, is there any harm if the input exceeds 5 volts? I assume the output will just be limited to 5 (or almost 5) and the op amp will otherwise be fine. Right?
    http://users.rowan.edu/~jahan/ECT/ECT_2007/presentations/324-opamp.pdf
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    yes no probs, you can input upto 8v over the supply .These are superb ics, i use them all the time.
  3. Tom1962
    Sep 10, 2012
    19
    Ok thanks, but just testing on the breadboard it seems that the output of the voltage follower can only go up as high as the voltage powering the chip, less two volts. In other words, if I power the chip with 5v, then the voltage follower only works up to about 3 volts. (My follower has the input going into pin 3, with pins 1 and 2 connected to form the output.)
  4. t06afre
    May 11, 2009
    5,939
    1,222
    About 3 volt out then supply voltage is 5 volt. Is according to the datasheet. If you need higher output voltage you may change to a so-called rail to rail opamp.
  5. Tom1962
    Sep 10, 2012
    19
    Not sure I understand what you are saying. If I power the chip with 12 volts, then I can use it as a voltage follower for a signal that ranges from 0 to 5 volts. Right?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Yes that is correct. The maximum output voltage is the supply voltage minus about 2 volt, in theory. So by using 12 volt as supply voltage. You should get 5 volt out with no prolem
  7. Tom1962
    Sep 10, 2012
    19
    And, just to confirm, if I connect pin 1 and 2, and feed the input signal into pin 3, the output voltage should be on pin 1 and 2 right? I see in the data sheet there is a schematic for a voltage follower with reisitors and capacitors. Do I need that circuit just to make a voltage follower?
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    Page 6 of the datasheet explains that the input protection for the Cmos inputs requires the resistor. The capacitor prevents attenuation at high frequencies.
    Almost all other opamps do not need them because this is a very old weird opamp.
