CA3046 isis-proteus
Discussion in 'General Electronics Chat' started by st_cuda, Feb 2, 2016.
  1. st_cuda
    Jul 21, 2014
    Hi, I want to build CA3046 npn transistor array in isis-ares.
    I used "make device" and set the pin numbers. but the pin 3 is the common pin of first two array.
    Here is the problem of mine when setting the pins of :
    Error is the following:
    How can I solve this problem? thanks
  2. absf
    Dec 29, 2010
    1,493
    374
    Because Q1&Q2 is different from Q3 or Q4 or Q5, dont think it is possible if you want to keep them in a 14-pin package with the mobility of each transistor.
    If without the Dip-package limitation, you can treat them as relay with multiple contact sets. Then you can refer to library Facilities\Device Libraries\Making a multi-element Heterogeneous Device and see how they did it.
    The best I can do it is this....
    If you do find a way. Please do let us know...;)
    Allen
  3. st_cuda
    Jul 21, 2014
    Thanks I know this way. But I am still trying to find what I want. Of course I will ;)
  4. hp1729
    Nov 23, 2015
    2,098
    232
    Does it give you a fatal error if you try to use pin 3 twice? In ORCAD I might get an error but it will still let it pass.
  5. absf
    Dec 29, 2010
    1,493
    374
    Yes it just wont let you get past at that stage.
    An alternative way is to assign a DIP-16 package and use pin 8 or pin 9 as the dummy pin 3 for Emitter:B Any pin > 7 is added with 2.
    Allen
