Hi, I'm looking for a C18 button example for the PICDEM 2+ board?
There is example 5 in C18 Getting Started pdf but there is a bug, for if you copy and paste example 5 and setup the pins correctly you only get the buzzer sound, and you can't press any of the 3 buttons to stop the buzzing noise like it says it should do upon building the project successfully.
Here is the example 5 code
#include <p18f4520.h> /* for the special function register declarations
#include <portb.h> /* for the RB0/INT0 interrupt */
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
void toggle_light (void);
#pragma code HIGH_INTERRUPT_VECTOR = 0x8
void high_ISR(void)
_asm
goto toggle_light
_endasm
#pragma code
#pragma interrupt toggle_light
TRISC=0;
PORTC=255;
void EnableHighInterrupts (void)
RCONbits.IPEN = 1; /* enable interrupt priority levels */
INTCONbits.GIEH = 1; /* enable all high priority interrupts */
void main(void){
EnableHighInterrupts();
OpenRB0INT (PORTB_CHANGE_INT_ON & /* enable the RB0/INT0 interrupt */
PORTB_PULLUPS_ON &
FALLING_EDGE_INT); /* trigger interrupt upon S3 button
depression */
CCP1CON = 0x0F;
while(1);
void high_ISR(void)
_asm
goto toggle_light
_endasm
#pragma code
TRISC=0;
PORTC=255;
void main(void){
PORTB_PULLUPS_ON &
depression */
CCP1CON = 0x0F;
while(1);
