c++ question
Discussion in 'Homework Help' started by TAKYMOUNIR, Oct 29, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    //can some one please chech the wrong in this code i am new in c++ i feel that this may be easy question but it is hard for me
    thanks
    // Chapter 6, Programming Challenge 2
    #include <iostream>
    using namespace std;
    // Write the prototypes for the getLength,
    // getWidth, getArea, and displayData
    // functions here.
    double getLength(double);
    double getWidth(double);
    double getArea(double);
    void displayData();
    int main()
    double length, // The rectangle's length
    width, // The rectangle's width
    area; // The rectangle's area
    // Get the rectangle's length.
    length = getLength(length);
    // Get the rectangle's width.
    width = getWidth(width );
    // Get the rectangle's area.
    area = getArea(length,width);
    // Display the rectangle's data.
    displayData(length, width, area);
    system("pause");
    return 0;
    // You must write the getLength, getWidth, getArea, *
    // and displayData functions. *
    double getLength(double x)
    cout<<"enter the length"<<endl;
    cin>>x;
    return x;
    double getWidth(double x)
    cout<<"enter the width"<<endl;
    cin>>x;
    return x;
    double getArea(double x,double y)
    double area=x*y;
    return area;
    void displayData(double x,double y,double z)
    cout<<"the length is\t"<<x<<endl;
    cout<<"the width is\t"<<y<<endl;
    cout<<"the area is\t"<<z<<endl;
  2. debjit625
    Apr 17, 2010
    790
    186
    The declaration of prototype for the functions getArea() and displayData() is wrong
    Always initialize your variables...
    Code ( (Unknown Language)):
    1.
    2. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// Chapter 6, Programming Challenge 2[/COLOR][/SIZE]
    3. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]#include[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]<iostream>[/COLOR][/SIZE]
    4. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]using[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]namespace[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] std;[/SIZE]
    5. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// Write the prototypes for the getLength,[/COLOR][/SIZE]
    6. [SIZE=2][COLOR=#008000]// getWidth, getArea, and displayData[/COLOR][/SIZE]
    7. [SIZE=2][COLOR=#008000]// functions here.[/COLOR][/SIZE]
    8. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getLength([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE]
    9. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getWidth([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE]
    10. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getArea([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]//Error two parameters[/COLOR][/SIZE]
    11. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] displayData([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2],[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]);[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]//Error three parameters[/COLOR][/SIZE]
    12. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]int[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] main()[/SIZE]
    13. [SIZE=2]{[/SIZE]
    14. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]//Always initialize your variables...[/COLOR][/SIZE]
    15. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] length = 0, [/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// The rectangle's length[/COLOR][/SIZE]
    16. [/COLOR][/SIZE][SIZE=2]width = 0, [/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// The rectangle's width[/COLOR][/SIZE]
    17. [/COLOR][/SIZE][SIZE=2]area = 0; [/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// The rectangle's area[/COLOR][/SIZE]
    18. [SIZE=2][COLOR=#008000]// Get the rectangle's length.[/COLOR][/SIZE]
    19. [/COLOR][/SIZE][SIZE=2]length = getLength(length);[/SIZE]
    20. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// Get the rectangle's width.[/COLOR][/SIZE]
    21. [/COLOR][/SIZE][SIZE=2]width = getWidth(width );[/SIZE]
    22. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// Get the rectangle's area.[/COLOR][/SIZE]
    23. [/COLOR][/SIZE][SIZE=2]area = getArea(length,width);[/SIZE]
    24. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]// Display the rectangle's data.[/COLOR][/SIZE]
    25. [/COLOR][/SIZE][SIZE=2]displayData(length, width, area);[/SIZE]
    26. [SIZE=2]system([/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"pause"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]); [/SIZE]
    27. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]return[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] 0;[/SIZE]
    28. [SIZE=2]}[/SIZE]
    29. [SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]//************************************************** *[/COLOR][/SIZE]
    30. [SIZE=2][COLOR=#008000]// You must write the getLength, getWidth, getArea, *[/COLOR][/SIZE]
    31. [SIZE=2][COLOR=#008000]// and displayData functions. *[/COLOR][/SIZE]
    32. [SIZE=2][COLOR=#008000]//************************************************** *[/COLOR][/SIZE]
    33. [/COLOR][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getLength([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x)[/SIZE]
    34. [SIZE=2]{[/SIZE]
    35. [SIZE=2]cout<<[/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"enter the length"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]<<endl;[/SIZE]
    36. [SIZE=2]cin>>x;[/SIZE]
    37. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]return[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x;[/SIZE]
    38. [SIZE=2]}[/SIZE]
    39. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getWidth([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x)[/SIZE]
    40. [SIZE=2]{[/SIZE]
    41. [SIZE=2]cout<<[/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"enter the width"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]<<endl;[/SIZE]
    42. [SIZE=2]cin>>x;[/SIZE]
    43. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]return[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x;[/SIZE]
    44. [SIZE=2]}[/SIZE]
    45. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] getArea([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x,[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] y)[/SIZE]
    46. [SIZE=2]{[/SIZE]
    47. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] area=x*y;[/SIZE]
    48. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]return[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] area;[/SIZE]
    49. [SIZE=2]}[/SIZE]
    50. [SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]void[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] displayData([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] x,[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] y,[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] z)[/SIZE]
    51. [SIZE=2]{[/SIZE]
    52. [SIZE=2]cout<<[/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"the length is\t"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]<<x<<endl;[/SIZE]
    53. [SIZE=2]cout<<[/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"the width is\t"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]<<y<<endl;[/SIZE]
    54. [SIZE=2]cout<<[/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"the area is\t"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]<<z<<endl;[/SIZE]
    55. [SIZE=2]}[/SIZE]
    56.
    Next time try to read the compiler's error...and please post your code using code tags
    Good Luck
    TAKYMOUNIR likes this.
  3. TAKYMOUNIR
    Jun 23, 2008
    351
    thanks very much for your help and please how can i send my code
