C programming doubt
Discussion in 'Embedded Systems and Microcontrollers' started by jimmyvarghese, Feb 27, 2010.
  1. jimmyvarghese
    Nov 25, 2009
    [​IMG] Help me.....
    include<stdio.h>
    void main()
    int i;
    char map[10]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6 F};
    TRISD=0x00;
    TRISC=0x00;
    TRISB=0X00;
    TRISA=0XF0;
    RC1=0;
    i=0;
    while(i<9)
    i++;
    PORTD=map;
    PORTB=0x01;
    _delay(196999);
    PORTB=0x00;
    _delay(196999);
    RC1=1;
    //RB5=1;
    RC0=0;
    this program is working in good condition.but i want add a switch control to it.now it is increament continuously.so i want to change this one as when we press the push button
    then only the increment happen
    http://www.electro-tech-online.com/attachments/micro-controllers/39578d1267253908-help-me-116.pdf
  2. andrew24
    Aug 20, 2008
    76
    Hello, one possibility is to create an interrupt from a pin where a button is conected (don't know is that possible with PIC, never worked with it) and in the ISR write some_kind_of_variable++ or something else you want, or in the endless loop check the state of o GPIO (if PIN==0..).
    In both techniques, you have to connect one side of a pin to ground, and other to GPIO/IRQ pin through a pullup resistor.
