C program that enables M68HC11 to operate it as a DATA LOGGER
Discussion in 'Programmer's Corner' started by sreeambition, Oct 20, 2010.
  1. sreeambition
    Oct 20, 2010
    Hi...Every one,
    I am new to this forum as well to this subject area so can any one help in this aspect so that I will be thankful to U.
    I need a C program that enables the M68HC11 to work it as data logger ,for that I need to include some of the components like A/D converter,counter,real time clock and should able to take samples.
    Thanks very much in advance .
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Oddly enough, it is extremely difficult to provide any assistance without some comprehensive specifications on the hardware and so on.
    In order to act as a data logger, it is only necessary that the μC take readings from the sensors periodically, convert them to standard units or values, and store them with a data stamp.
    If you can read the sensors, the rest is pretty easy.
