C program for the temperature monitoring circuit with pic 16f877a with pc interface
Discussion in 'Embedded Systems and Microcontrollers' started by lekshmipriya1989, Apr 7, 2011.
  1. lekshmipriya1989
    Apr 7, 2011
    the circuit uses a pt100 sensor for temperature sensing and then interfacing of pic 16f877a adc and then displaying using a 16X2 alphanumeric lcd.then transmitting the temperature reading via rf12b transceiver module and then interfacing it to a pc..
    I NEED A C PROGRAM TO IMPLEMENT THE SAME,,
    IT SHOULD INCLUDE
    DATA ACQUISITION FROM PT100,ANALOG TO DIGITAL CONVERSION,THEN DISPLAYING IT TO LCD.(AFTR ASCII CONVERSION) THEN TRANSMITTING USING RF12B AND RECEIVING USING THE SAME.(COMMUNICATION BTWN THE 2 RF12B TRANSCEIVERS) AND THEN THEIR INTERFACE WITH PC..
    I NEED THE WHOLE PROGRAM FOR THIS...
    PLZZ HELP..ITS VERY URGENT...​
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Thank you for coming to AAC for a major programming project. It would be really nice for the membership to crank out code for you to take credit for (or even receive payment for).
    However - that is not quite the way it works. We can provide advice on details of the interface (not at all described) and some pointers about the data acquisition, engineering unit conversion, and data transmission, but it is your project and therefore your responsibility to make the entire effort to get this project designed and running.
