C-Operator Hardware implementation
Discussion in 'General Electronics Chat' started by lukmax, Aug 19, 2014.
  1. lukmax
    Jul 24, 2014
    6
    I'm trying to estimate the number of logic gates used to build different C-operators. Gates needed is dependent on the input and delay factor but for the beginning I just want to consider the input (how man bits..).
    For example, the most easiest are bitwise operators. There we have 1 Gate needed.
    Now I'm trying to find estimates for..
    Relational, logical and ternary operators
    sqrt
    .. Besides the fact that there are many implementation possibilities of these operators, do you have an idea where I can get some Gate counts?
    Thank you for the help
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Most of the C operations are actually comprised of many steps as an algorithm - such is the nature of such a high-level language like C.
    There comes a point where the circuit required to implement an operation is better suited to using either as lookup table or an algorithm rather than a hardware implementation.
    If you really want some gate counts, some truth tables describing each operation would help you identify the required gates. You will need to select a data size to operate on.
