C++ Help
Discussion in 'Programmer's Corner' started by SHuzero, Aug 21, 2011.
  1. SHuzero
    Feb 22, 2011
    14
    can help me to design a program that simulates a radio station's contest that awards a $10,000 prize to the first caller who correctly guesses a number in a list of randomly generated numbers. A caller can make one guess per call. The contest is held until a number has been matched or the user enters a value of -1. The code used to generate a random list between 1 and 500 is in createlist.cpp. The list generated from running is createlist is prizelist.txt. The following list is the file Prizelist.txt 42,468,335,1,170,225,479,359,463,465,206,146,282,329,462,492,496,443,328 and 437.
    I hope you can help me....
  2. SHuzero
    Feb 22, 2011
    14
    this is the sample output
    a message is displayed containing the winning number, the location in the list of numbers, the number of calls made, and the amount of the prize.
    Hello Caller. What number between 1 and 500 are you guessing ? 250
    250 is not in the list. Call again.
    Hello Caller. What number between 1 and 500 are you guessing ? 700
    Your guess must be between 1 and 500 inclusively.
    Hello Caller. What number between 1 and 500 are you guessing ? 42
    Caller. Your number 42 was found at location 1 of the list.
    Counting you, there were 2 callers. Your winning are $10,000
    It uses a arrays sequential search can you help me.....
  3. debjit625
    Apr 17, 2010
    790
    186
    What you have done so far?any code you wrote... any example you tried...
  4. SHuzero
    Feb 22, 2011
    14
    i only write the input & output message plus the file.... i don't know how to right the array with file plus the sequential please help me....
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    It's a simple loop using the rand method.
