takao21203
- Joined Apr 28, 2012
- 3,702
If you don't give the information what type of softwares you want to write with that C compiler, it is difficult to write an answer that makes sense.Hi All!
I need a C Compiler for Windows 7 32 bit! I am currently using Visual Studio 2010...it works Ok but creates several other files...Kind of annoying!
You can provide links if any...
Thanks!
VS (Visual Studio) includes documentation (at least the paid versions), native support of different Microsoft technologies such as DirectX, GDI+, .NET (for example), and there is a strong online community (MSDN forums). As well, many print books do exist.
If the ancient Turbo C or the Borland C are mentioned, they only include a tiny percentage of all that functionality.
It depends also on how complex are the programs you typically write or want to write.
In VS you can generate a blank form using the wizard. You can read explanation of all the language basics directly from the documentation on your computer. You get examples.
All this is actually missing from UNIX and LINUX C compilers (Free BSD for instance). You need insider knowledge or good literature to get these working.
I have used Turbo C sometimes. It is totally antiquated. Segmented MSDOS memory.
