c code for pic16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by shicibukai, Feb 21, 2013.
  1. shicibukai
    Feb 21, 2013
    6
    i have a project to design a automatic switching capacitor for power factor correction system.. the pic will eventually detect an input from current transducer. the current transducer will detect current value n convert to number(0-255) i think... if value is from 0-100... o/p A will trigger... if value from 101-150, o/p B will trigger and if value from 150-255, o/p C will trigger.. A,B,C is refer to different output from the pic16f877a. these 3 output then will be connected to capacitor.. the problem is, i don't know how to assign those output to specific input current value. im a newbie here and im just starting to study the microC. can anyone help me with the C code? thanks..
  2. ErnieM
    Apr 24, 2011
    7,436
    1,625
    You should start by getting the cart behind the horse.
    You should not start to automate a process you do not yet understand. Power factor involves the phase delay between the voltage and the current, not the absolute value of either. That is a time measurement, not voltage.
    Once you understand THAT a good thing to do is to breadboard your solution with mechanical switches and caps to see if you truly do have a fix.
    Also understand that your algorithm should be advancing to caps, since once a particular cap is in circuit a factor change means you need switch to the next cap, not any particular cap.
    THEN... learn the language to program the controller. C is a good choice and is freely available.
    Finally... you can start on some hardware and software planning.
  3. shicibukai
    Feb 21, 2013
    6
    ok i understand that.. i would like to know is the input of pic is digital number between 0-255? which mean i can separate the number to trigger several output port? just like i explain before.
  4. shicibukai
    Feb 21, 2013
    6
    how to trigger certain output for certain value of input?
  5. tshuck
    Oct 18, 2012
    3,531
    675
    You would need to evaluate the input and take action accordingly.
    As ErnieM has already stated: you need to start at the beginning. learn the concepts, then apply them. You'll get nowhere otherwise...
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Yes you can work on a single bit level on a PIC I/O port. You can also use bit twiddling methods to some extent modify several bits simultaneously on a port. I do not know which C compiler you use so I can not be more specific. If you want to know more about bit twiddling. Just Google bit twiddling
  7. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Digital or analog input?
    Each digital I/O pin could represent a single binary digit, jam 8 inputs together and you can get it to mean a number from 0 to 255.
    Each analog input can be sent to an analog to digital (A2D) converter. The A2D on this device can give you a conversion of either 8 bits (0-255) or 10 bits (1-1023).
    But as I said before, power factor is best measured by a time measurement.
  8. shicibukai
    Feb 21, 2013
    6
    anyone can provide me c programming and circuit for automatic capacitor switching of power factor correction system using pic16f877a?. im really new into this.thank you. im willing to pay but not so much :(
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    We are not an answering service.
    When we would give you a complete solution, you would have learned nothing.
    So, show us how you would approach the problem.
    Bertus
  10. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Nope, sorry, but nice try. :p
    You have the barest of ideas here, which while it is a start is just right at the starting line, and no where near the "begin writing code" stage. So you are asking someone to flesh out the concept (how to measure power factor and how to change it), design all the hardware for you, select the components, then to write the code for it.
    After all that you are willing to pay them "but not so much."
    You need to pick a new direction with this project.
  11. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    There are special briefings from Microchip, also run by a few independent organisations.
    Usually not free, but the independent one's normally don't cost so much.
    That is what OP should attend, if he's any serious.
    Otherwise, there is no way around to study and examine how the fundamentals work. Reading datasheets, and doing tutorials, getting PICs, and all that.
    Giving some C code could do more damage than any helping.
    Once OP has a circuit and a working program, forum members can assist to look at the code, and add things, and improve it.
    If OP wants to hire a programmer to produce a C code, this won't be cheap, $50/hour is on the downend. It needs to be a professional, if it is an amateur, maybe the work will leave OP with more questions and problems than before.
    From many PIC related forum posts, I really must believe these people never seriously examined the Microchip website. There are many things to discover.
  12. shicibukai
    Feb 21, 2013
    6
    ok sorry.. i will try do the circuit diagram first using proteus. then i upload here to see if i doing the right thing or not :)
  13. takao21203
    Apr 28, 2012
    3,578
    463
    You don't write your country, so you can not get advice for that. Maybe not as expensive as you think.
