C and Cpp
Discussion in 'Programmer's Corner' started by Rajadurai, Feb 6, 2011.
  1. Rajadurai
    Feb 6, 2011
    HOw to Change the C programme into Cpp Programme
  2. AlexR
    Jan 16, 2008
    735
    54
    Why do you want to change it? A C program should compile on a Cpp compiler without any modification.
  3. spinnaker
    Oct 29, 2009
    5,081
    1,181
    Add a PP??? :)
    CPP compilers can compile C.
    You will need to give a whole lot more detail if you want help.
    But a course in CPP programming is well beyond the scope of this forum. There are many classes that can be found online.
  4. elavarasu
    Feb 9, 2011
    It is possible both c programs and c++ programs runs under c++compilers.
    if you are write a program in c platform ,you will need to save the program(filename.c)(.c extension)(for ex:coffee vending machine.c)
    if you are write a program in c++ platform ,you will need to save the program(filename.cpp)(.cpp extension)(for ex:coffee vending machine.cpp)
    but the only problem is ,if you are write a pgm in c platform using it's function,it will not to convert a .cpp file
    because input and output functions are different.
    the upcoming versions compilers are
    a)borland C++
    b)turbo c
