C++ adding digits from an integer
Discussion in 'Programmer's Corner' started by MJ320, Oct 10, 2010.
  1. MJ320
    Oct 10, 2010
    I'm new to C++ and I'm trying to write a program using functions to allow the user to input an integer. The program then takes the integer and adds up the sum of the digits. I keep getting the answer showing up as 0. Any help is appreciated...
    #include <iostream>
    using namespace std;
    int extractedDigit;
    int number;
    int newNumber;
    long sum = 0;
    int sumDigits(long sum = 0)
    int result;
    if (newNumber / 10 != 0)
    extractedDigit = number % 10;
    newNumber = number / 10;
    sum += extractedDigit;
    else
    number = sum;
    return result;
    int main()
    //Prompt user to enter an integer
    cout << "Please enter an integer: ";
    cin >> number;
    cout << "The sum of the integers in " << number << " is " << sumDigits(sum) << endl;
    system ("Pause");
    return 0;
  2. shteii01
    Feb 19, 2010
    3,504
    512
    Put a bunch of cout to see what happens every step of the way. That is how I troubleshoot my programs.
  3. DonQ
    May 6, 2009
    320
    11
    Your routine never did put any value into "result". It is a function of the environment that the 'auto' variable "result" happens to contain zero. Normally, it is not guaranteed to init to any particular value and would return a random(ish) number depending on what happened to be at that location on the stack when sumDigits() was called.
    Put a value into result before sumDigits() returns.
