Bypassing Volumecontrol Creative Inspire T3030
Discussion in 'General Electronics Chat' started by stefa, Jul 8, 2012.
  1. stefa
    Jul 8, 2012
    Hello, I recently bought a Creative Inspire T3030 soundsystem on a second-hand-market, but I didn't check the system properly enough. When I arrived home i discovered that the volumecontrol is not fitting the connector on the subwoofer.
    The subwoofer has a 9-pin female connector:
    and the volumecontrol has a male PS/2 connector like this one below:
    The soundsystem is not possible to use without a "volume and power"-control, but I do not need the funktion of a volume or power-control on my speakersystem. I'm going to use it as computer-speakers and I will set the volume from my taskbar.
    :confused: Is there anyway I can bypass some of the 9 pins so I will have constant maximum volume and constant power to the system??
    I have read a few earlier threads about Creative T3030 problems with the volumecontrol, but I find no info on how to bypass it. I have found this info:
    Pin1- Brown
    Pin2- Green
    Pin3- Yellow
    Pin4- White
    Pin5- Violet
    Pin6- Blue
    Pin7- dummy / not connected
    Pin8- Black
    Pin9- Red/violet
    and later I found this info:
    red (head phones jack)
    black, red (LED)
    blue (volume switch)
    yellow (head phones jack)
    white (volume switch)
    black, red
    white (volume)
    green (bass volume control)
    Violet (audio jack)
    Thnx in advance // Stefan
  2. Eagle849
    Jul 11, 2012
    Does anyone have same info with pictures for Gigaworks G500 remote or 9 Din connectors similar?
    Thanks in advance.
    Vitaliy
  3. R!f@@
    Apr 2, 2009
    8,785
    771
  4. Eagle849
    Jul 11, 2012
    Problem is, different colours from T3030
    Pin1- Brown
    Pin2- Green
    Pin3- Yellow
    Pin4- White
    Pin5- Light Green
    Pin6- Blue
    Pin7- Orange
    Pin8- Black
    Pin9- Red
  5. mastermindiz
    Mar 18, 2015
    Hello
    Does anyone have info with pictures for
    creative fps2000 remote pinout?
