Bypass capacitors breadboard
Discussion in 'General Electronics Chat' started by Tony Elliott, Jun 4, 2016.
  1. Tony Elliott
    May 8, 2015
    140
    image.jpeg image.jpeg image.jpeg Hi All,
    Here is my Voltage Controlled Amplifier breadboard and schematics. Do the bypass capacitors look right place to you. The schematic is fairly vague on this so this is how I interpreted it.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Tony Elliott likes this.
  3. Tony Elliott
    May 8, 2015
    140
    Yes this is the schematic I am looking at. Does it look right on my breadboard? Cheers
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    There's usually so much stray coupling on breadboards that it's not practical to even worry about supply decoupling.
    When you transfer the design to a PCB, put a decoupling on the power pins of every IC.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Where are the two transistors?
    I do not see them on the breadboard.
    As said, better make the PCB given on the webpage.
    As for the decoupling capacitors, you could use the guidelines as given in this thread:
    Decoupling or Bypass Capacitors, Why?
    Bertus
  6. Tony Elliott
    May 8, 2015
    140
    I am making it now, that is why there are no transistors. Thanks for the link:)
