Buzzing power strip
Discussion in 'General Electronics Chat' started by electronewb, Sep 21, 2013.
  1. electronewb
    Apr 24, 2012
    260
    I can hear a major buzz coming from a power strip that I have even with no load on it. What could be wrong with it and should I bother fixing it or just toss it out and buy a new one? And also is there any hazard to use that power strip?
  2. RichardO
    May 4, 2013
    1,335
    429
    It sounds real dangerous to me. I would pitch it.
    But first, I would open it up to see what is going on. :)
    (I am guessing that a couple of the contacts are lightly touching.)
  3. wayneh
    Sep 9, 2010
    12,374
    3,226
    Is this anything more than a power strip? I mean, surge suppressor, circuit breaker, etc.? A picture might help.
    But yeah, I wouldn't use it until it was fixed. And I wouldn't fix it unless you feel comfortable doing that.
    Don't do anything while it's plugged in.
  4. electronewb
    Apr 24, 2012
    260
    it's a "high end" surge protector power strip It's old but paid a pretty price on it I'll try to snap a picture
  5. GopherT
    Nov 23, 2012
    6,303
    4,019
    It likely has a small SMPS inside to run the LED and any additional gadget. Something seems to be failing if it is loud. If it is just barely audible, it could just be a resonance with the mounting frame that is vibrating. The magnetic field can cause the metal around the SMPS to vibrate in the audible range.
