buzzer to sensor output
Discussion in 'Homework Help' started by simo_x, Jan 2, 2011.
  1. simo_x
    Dec 23, 2010
    200
    6
    Hi all, I have to make a simple circuit with an EESPY401/402
    I thought to put a buzzer connected to the output pin, connecting the buzzer to the Vcc and the output voltage to make it turn on when the sensor detect some object.
    But in the datasheet example, it figure a relay as Load 1. If I don't use a relay, my idea would be ok?
    Thank you.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, your idea is OK
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    It also depends on the type if buzzer you want to use.
    If you want to use some piezo beeper, take care it has a buildin oscillator.
    Bertus
  4. simo_x
    Dec 23, 2010
    200
    6
    So, If I would like to put a relay, just connect the coil to Vcc and Out (as I thought for the buzzer), and connect the buzzer to the NO of relay and ground. This should be also Ok if I am not making errors. Right?
    Hi Bertus, thank you, but I forgot to say that the circuit will just be theoric, anything practice. I don't think this will be really important, but I keep in mind your suggestion, I did not know this detail.
    Thank you
