hello guys!
i want to use a button as switch but not only...
for example when i press it for 3sec then this becomes ON and if i press it again for 3sec then OFF, this is the easy part. the problem is that the ON situation is like a locator whitch use a piezo buzzer that sound every 15 or 3o or 60sec time tha i select from the same button.So the button work is: 3sec press=on, 6sec press=every 15sec buzzer ring time, 8sec press=every 30sec buzzer ring time, 10sec press=every 60sec buzzer ring time and if i release it and press it again for 3 sec then it becomes off if i dont release it then it start again the selection between ring times...
any help with the code?
im using mikro C and pic16f88
thanks a lot!
thanks a lot!
