Button Push to Computer Input
Discussion in 'General Electronics Chat' started by silverwood, Feb 11, 2009.
  1. silverwood
    Feb 11, 2009
    I don't know if this is the right place to post this but i've been searching the internet and a lot of my hits are the forums on this site.
    I am looking for a tracking system. Basically I am trying to track money being put into a box.
    When the money is put into the box a switch or trigger is shorted/activated (like when you put a quarter in a arcade game). I have no idea on how to get that signal onto a computer so that I can track how many times money is put in the box. I know that it can be done I just don't know what I need to do it.
    Any help would be greatly apreciated.
    Thanks,
    Danny
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A simple method if to arrange a beam of light to be broken by the coin. Arrange the output from the sensor to be a logical 0 (unbroken) or 1 (broken) and it can be applied as an input to any computer/microprocessor. You caould use an IR LED abd phototransistor, or a photointerrupter for the job.
    Hopefully, this isn't for serious use. Modern coin operated devices use somewhat sophisticated means to distinguish between real coins and fake. If you intend to use the sensor to accept that a coin has been fed in, what happens when a washer of the right size, or a slip of opaque paper is inserted?
  3. silverwood
    Feb 11, 2009
    I have a way to detect when money is put into the box, but I don't know what kind of device to use that would take that signal and convert it so that the computer can make record of it in a database.
  4. RiJoRI
    Aug 15, 2007
    536
    26
    Life was a lot easier with the older computers where you did not need to battle the OS. You could scan the printer signal lines or the serial port control lines. These days I would grab a microcontroller and use it to transfer the pulse(s) into an ASCII character, and send it out the serial port to the computer.
    --Rich
  5. Barry M
    Feb 11, 2009
    35
    So theres a mechanism in place and you want to computerise it?
    I think you'll need to give the specs of the mechanism in place first to see what signals are readily available off of it and then theres the software to capture those signals and convert it and the database stuck on the end ... but Im a noob so who knows.
  6. PIC_User
    Member
    Sep 22, 2008
    20
    Hi Danny,
    Could get your circuit to actuate a small reed relay to give “dry” (no outside voltages) on/ off contacts?
    -Adam-
  7. cmartinez
    Jan 17, 2007
    3,698
    2,764
    Danny,
    You need to use a microcontroller for that. I strongly suggest an ATMEL with an 8051 architecture since it's rather easy to program.
    Use an optical sensor as beenthere suggests, and then transfer the detection to the computer via RS232
    So the questions are:
    - How experienced are you with digital MCU's?
    - What's your expertise with sensors and signal conditioning?
    - How much time are you willing to put into this project?
    Czar
  8. cmartinez
    Jan 17, 2007
    3,698
    2,764
    Danny,
    Czar
  9. PIC_User
    Member
    Sep 22, 2008
    20
    Hi Danny,
    If you can control the reed relay with your circuit:
    Get a standard cheapest ($5-$7) available USB “3 button Mouse”.
    Open it.
    Wire the relay contacts across the middle button.
    Every time the relay is actuated, the computer thinks the middle button of the mouse has been pressed.
    Use simple free software to “read” the middle button press.
    This is open source, freeware that seem to work great.
    autohotkey.com
    You can set up a script. It lets you do all kinds of things.
    Their forum has a lot of code examples.
    Some of the examples show mouse button clicks.
    The good part is that you do not need any driver software for the device because Windows reorganizes it as a mouse (Human Interface Device - HID). The mouse contains the debounce conditioning for it's normal push-button.
    -Adam-
