Butterworth
Discussion in 'Homework Help' started by Cerkit, Apr 16, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I have to derive the transfer function of a third order Butterworth low-pass filter with cutoff frequency 200 Hz. is the following correct?
    (|H(jω)|^2)= 1/(1+ω^2n)
    let ω=s/j
    H(s).H(-s)=1/(1+(s/j)^2n)=1/(1+((-j)^2n).(s^2n))
    H(s)=1/(1+s^6)
    if this is correct how does the extraction of the H(s) bit occur from the H(s).H(-s). Please can someone explain to me. Thanks
  2. Darren Holdstock
    Feb 10, 2009
    262
    11
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Chapter 2 of this book covers some equation derivations.
  4. Cerkit
    Jan 4, 2009
    275
    It is a lot of information but there has been no direct feedback to what I put up...
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    What are your handwavium steps denoted by ":"?
  6. Cerkit
    Jan 4, 2009
    275
    Intermediate steps
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    Can you post the intermediate steps?
    Or do you have the question, and answer, but not the middle part?
    The intermediate steps imply you worked through the formula to get to that answer.
  8. Cerkit
    Jan 4, 2009
    275
    The question is "Derive the transfer function of a third order Butterworth low-pass filter having a cutoff frequency equal to 200 Hz".
    What I have put is as far as I get through reading notes on filters. I don't know if it is correct. The intermediate steps are large jumps i have made which are jumps in calculations also in my notes.
    Therefore not sure if my answer is right and if it is what the exact steps are...??
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you post a schematic of the third-order Butterworth low-pass filter circuit?
    hgmjr
