I'm currently having issues with my Matlab code for the following problem:
1) The numeric Matlab command, [n,d]=butter(k,w0,'s'), will generate a vector of numerator coefficients, n, and the vector of denominator coefficients, d of a filter. The parameter k is a positive integer, usually less than 10; the parameter w0 is positive.
(a) Use the command pzmap(n,d) to investigate the poles and zeroes of such a filter. Clearly discuss the effect of the parameters k and w0 on the poles and zeroes of the filter. Develop figures that clearly illustrate the behavior of the poles and zeroes of such a filter.
My code is:
When I run this, I get the error:
??? Maximum variable size allowed by the program is exceeded.
So I tried changing inf to a number such as 0.1, but I get another error:
??? Error using ==> butter at 41
The cutoff frequencies must be greater than zero.
What am I doing wrong here?
Could please help me?
My many thanks in advance
My code is:
Rich (BB code):
syms k w0;
% k is a positive integer, less than 10
k=0:0.1:9;
% w0 is positive
w0=0:0.1:inf;
