butterworth digital low pass filter
Discussion in 'General Electronics Chat' started by vead, Jan 13, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    butterworth digital low pass filter has following specification
    passband-0-500 hz
    stopband-2-4 khz
    passband ripple-3 db
    stopband attenuation-20 db
    sampling frequency-8 khz
    determine the passband and stopband edge frequency
    please tell me the hint or formula to calculate passband and stopband frequency
  2. Veracohr
    Jan 3, 2011
    559
    77
    Surely whatever class or book this question came from also gave you the tools to answer it. Else what is the point of the class?
    However, it doesn't make sense. A Butterworth filter shouldn't have passband ripple.
    If you can assume it's a Butterworth filter (no passband ripple) or that it's a Chebyshev filter with 3dB passband ripple, then the beginning of your answer is right there. You have the minimum frequency your passband must extend to, you have the maximum frequency your stopband must start at, and you have the attenuation that must be seen at the start of the stopband. The class or book or whatever should have explained how to take those numbers and determine the filter order needed and cutoff calculation.
  3. Fritz Kreisl
    Jan 13, 2014
    butter designs lowpass, bandpass, highpass, and bandstop digital and analog Butterworth filters. Butterworth filters are characterized by a magnitude response that is maximally flat in the passband and monotonic overall.
    <snip>
  4. vead
    Nov 24, 2011
    621
    8
    this is unsolved question I don't have anything to solve it i have googled and spend lot of time to find out but I didn't found anything
  5. shteii01
    Feb 19, 2010
    3,500
    511
    Ok. You have a transfer function. You plug a frequency into the transfer function, do the math, you come up with a number between 0 and 1.
    When you plug a cutoff frequency of the filter into the transfer function, the result is 0.707, so 0.707=transfer function. Now solve it for the frequency.
  6. LvW
    Jun 13, 2013
    674
    100
    Hi vead,
    Some days ago you have opened another thread dealing with the same subject :
    http://forum.allaboutcircuits.com/showthread.php?t=93040
    In my answer (post#2) I told you that there is no simple formula for calculating such a filter. First, you have to choose one of different design strategies available.
  7. vead
    Nov 24, 2011
    621
    8
    that was different post but topic is same I thought may be someone can help in this way but now I think no one can help me I have to do myself
  8. LvW
    Jun 13, 2013
    674
    100
    Rather, I think it is not possible to help you based on some rough information in this forum. The task is rather complex and requires more work than can be done by simply ask questions and give answers.
  9. atferrari
    Jan 6, 2004
    2,663
    783
    Not a bad idea, I think.
