BUS REGISTER
Discussion in 'General Electronics Chat' started by blue6x, Apr 18, 2005.
  1. blue6x
    Thread Starter Active Member
    Apr 6, 2005
    38
    does anyone here knows how an 8 stage shift and store bus register, three state works... The device name particularly is HC4094F, I have very little background on bus registers and I just hope you could help me particularly that question of mine. Thanks...
  2. pebe
    Oct 11, 2004
    628
    With this chip, 8 bits of data are clocked in serially into an internal register. That data can then be put on to an 8line data bus by means of an 'Output Enable' pin on the chip.
    You can get the data sheet here
    http://www.datasheetarchive.com/datasheet/pdf/72/726353.html
  3. blue6x
    Apr 6, 2005
    38
    hey, thanks... i'll check it out
