Bus Pirate - UART Live Monitor
Discussion in 'Embedded Systems and Microcontrollers' started by mbxs3, Sep 9, 2016.
  1. mbxs3
    Thread Starter Active Member
    Oct 14, 2009
    143
    I am attempting to monitor the data that is being sent from an embedded linux device to a peripheral piece of equipment in a system.
    Please see attached diagram I have made depicting the normal system connection and how I am thinking I can monitor the data using the bus pirate.
    EDIT: I did not depict that the peripheral device uses a MAX232 RS-232 Transceiver
    My question is whether or not this would be a valid method for monitoring this data communication. I am only interested on what the peripheral device is receiving from the linux device. Assuming this physical monitoring setup is correct, am I correct to think that the UART live monitor macro should allow me to capture this traffic?
  2. MaxHeadRoom
    Jul 18, 2013
    10,816
    2,493
    I use this program for RS232 capture, either one way or both ways.
    http://www.viddata.com/
    Limited free trials.
    Max.
