Hi everyone
I'm new to the site, I'm not that technical but I'll have a go. Appologies in advance for my lack of knowledge but is offset up by my enthusiasm to learn .
I stumbled on the following link http://forum.allaboutcircuits.com/showthread.php?t=16593 while trying to find a 'burst' timer. Can anyone tell me if it's possible to modify the circuit so that it self triggers approx every 15 minutes with the output variable from approx 5-30 seconds.
I would like to use it to control a greenhouse mister. The setup will be controlled by humidistat to switch on when humidity drops too low and the output will be to a 24v solenoid to actuate the mister. I need to keep the greenhouse in tropical conditions!
Thank you
Steve
Thank you
Steve
