On what do you base your assumption the neutral 'seams' to always burn first?Why is it that on 120v wall receptacles that the neutral seams to be the one side that always burns first? Current flow should be equal.
Good point. Let me rephrase, the left wider one with no shorts to ground occurring.On what do you base your assumption the neutral 'seams' to always burn first?
P.S. "Seams" is for sewing.
And the current flow in the neutral and the 'other side' aren't necessarily equal because the third side - the safety ground - can also carry current during a fault.
What do you mean by "burns first"? Turn brown, apparently from heat? I don't have any receptacles that "burn" or look burnt. The house is "only" 23 years old, but I don't think a wall outlet should ever burn or discolor unless it is repeatedly overloaded so that it gets darn hot.Why is it that on 120v wall receptacles that the neutral seams to be the one side that always burns first?
Not sure that rephrase clarified anything for me.Good point. Let me rephrase, the left wider one with no shorts to ground occurring.
Best answer yet. Still though, many times it is really burnt, more than just soot.When you say "burn" do you mean the plastic melts or do you mean the neutral prong gets blackened, like with smoke? Can you wipe it off? I will assume it is the latter.
In welding, smut forms on the piece being welded more than on the working electrode. One of the contributors to that is thought to be the temperature differential. The electrode being hotter than metal surrounding the weld promotes whatever is oxidized to make smut to condense on the colder surface..
This may be crazy, but maybe the larger bulk of the neutral means it stays colder than the smaller hot prong. And after many insertions with arcing to either electrode, the neutral may accumulate noticeably more smut on it.
Just a swag.
John
