Burner circuit for 8051 microcontroller
Discussion in 'Embedded Systems and Microcontrollers' started by kamesh, Apr 22, 2009.
  1. kamesh
    Apr 22, 2009
    hello everyone, can anyone tell me why burner circuit is actually required for downloading the hex file to 8051??? can it be not burn without using the burner, if it can be burn then can u please give me any suggestion, i will be very thankful to u.
  2. FBorges22
    Sep 11, 2008
    108
    Burner? You mean the programmer?
  3. kamesh
    Apr 22, 2009
    yes i mean the programmer
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    No. The "burner" is not actually required for some microcontrollers. Example, for the Atmel At89C5131, you can "burn" the hex codes into the chip via a USB cable from the PC.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  6. FBorges22
    Sep 11, 2008
    108
    There is this one too:
    www.ikalogic.com
    This site contains a article talking about a isp programmer I made one that´s worked with the AT89S8253
  7. kamesh
    Apr 22, 2009
    thank u all for ur kind replies......
    i m having another query that whether all interfaces connections with AT89C51 will remain same with AT89S51 if there are changes can u pls inform me???
  8. dsrelation
    Mar 8, 2013
    Can any one discuss a burner as a copier ?
  9. @android
    Member
    Dec 15, 2011
    178
    9
    Remember that core architecture of 8051 doesn't change. No matter what manufacturer you are refering to. All that will change is features offered.
